Brakes
Old Jun 14, 2004 | 08:55 PM
ThraxXx's Avatar
Car: 1988 Pontiac Trans Am
Engine: 5.0L Fuel Injection
Transmission: Automatic 4speed /w OVerdrive
Brakes
I am having a weird problem with my brakes. sometimes the brakes are fine and they do their job like they are supposed to and other times they are stupid sensitive. Like a light tap of the brakes can lock the front end right up. Also after driving the car and parking it I can hear this clunking noise in the front end as the calipers slowly seperate. I think the calipers are tired and need to be replaced...which is probably what I am gonna do. Is there anything else that I should get done as well?
Old Jun 15, 2004 | 02:59 AM
transambill's Avatar
Car: 91 Firebird Formula
Engine: ZZ4 fast burn with TPIS mini ram.
Transmission: Viper T10 6 spd.
Your discription sounds like there is blockage somewhere in the front lines and when you park your car your hearing the pressure bleeding off from your front calipers.
Try replaceing the front rubber brake hoses first since you should do that when replaceing front calipers anyway and I bet it fix's the problem without replaceing the calipers.
BADNBLK
Convertibles
Sep 21, 2015 07:56 PM
dbrochard
Sep 19, 2015 08:13 PM
Necron
Brakes
Sep 14, 2015 12:45 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
