ball joint
Old Jun 16, 2004 | 09:29 PM
84 t/a 5.0's Avatar
Car: 1984 Trans Am H.O.
Transmission: 700-R4
Axle/Gears: stock 3.73
ball joint
checked out my ball joint on the passenger side, and it needs to be changed. will i need a press to get the old one out and the new one in? any other tools I will need?
Old Jun 17, 2004 | 03:58 AM
ede's Avatar
ede
you need a press and you need other tools pickle fork, sockets, and few common hand tools. torch and impact make things lot easier.
Old Jun 17, 2004 | 03:30 PM
BretD 88GTA's Avatar
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
Re: ball joint
You can rent a hand-held balljoint press from AutoZone. Be prepared though, as it takes quite a bit of force to pop the balljoint out. A large breaker bar helps for leverage.
Your other option is to remove the A-arm and take it to a machine shop. They will use a hydraulic press to remove and install the balljoints. Should only cost around $10 each.
Old Jun 17, 2004 | 08:04 PM
84 t/a 5.0's Avatar
cool, thanks for the info
Ed1LE
Sep 30, 2018 09:14 AM
Thirdgen89GTA
Oct 19, 2015 09:27 AM
88CamZ
Oct 8, 2015 10:29 AM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
