tire choices....
Old Jun 17, 2004 | 05:59 AM
80's Al's Avatar
Car: 89' RS TPI,04' HEMI Dodge Q-cab
Engine: 383ci
Transmission: TCI 700R4, 3400 stall
Axle/Gears: 12 bolt 3.73
tire choices....
I want to go with a 275/50r15 Hoosier DOT tire. Mounted on an 8" Corvette Ralley.
Anyone runnin these?
My other choices are BFG Drag Radials, or the Nitto Drag Radials.
Any comments/ideas?
Are there any others out there I should consider?
This will be a "nice day to work/track/weekend warrior" car!!
Old Jun 17, 2004 | 09:24 AM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
Transmission: DYT700R4 custom inerts and conv.
"R" coumpound Hoosier competion tires will wear out within 1 week of mormal street driving in mild to hot temperatures outside.
They are designed with two different compounds: one for autocross, one for roadracing (A little harder compound with more steel belts so they don't heat up as quickly). Neither will last on the street. They are for limited track mileage wear only. The DOT is for racing classes that require a DOT tread pattern restriction.
Old Jun 17, 2004 | 09:48 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
Dean,
I think he is talking about Drag tires, to R or A compound competition tires.
And i do beleive your explanation has R and A backwards, A compoud should head up faster (small course ) R compounds are a little harder, and heat up slowler (long course).
Old Jun 17, 2004 | 06:45 PM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
Originally posted by Dewey316
Dean,
You must be tired John- gotta read what I wrote again. Above he asked first about Hoosiers, then the drag radials.
On the second note I listed roadrace tires(A little harder compound.....) That wasn't "A little"- as in "A" coumpound-roadrace versions are "R" compounds
Old Jun 18, 2004 | 07:08 AM
80's Al's Avatar
Engine: 383ci
Yep, talkin 'bout the Quick Time DOT tires.
I've heard Nitto's are a longer tread life tire than the BFG's.
Anyone?
Old Jun 18, 2004 | 07:56 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Ok. ok. and yes I am tired. I work too much.
(it must be really bad, i cannot beleive i used that poor of grammar)
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
mattcanty
Oct 12, 2015 11:08 AM
