What size tires?
Old Jun 23, 2004 | 10:53 AM
pigsticker's Avatar
Car: 1992 z28
Engine: Vortec 350 TPI
What size tires?
I've got a 92 z28 that has 255/50/16 on the rear now. If I wanted to go to a tire a little wider and taller, what size would I need without causing any problems?
Old Jun 23, 2004 | 11:02 AM
Bandit5's Avatar
BFGoodrich Radial T/A 265/50/R16
That is about as wide as you can go safely on those wheels. Without changing wheel size, i wouldn't reccomend anything more than that. But personally, I would use BFGoodrich G-Force T/A KDW in 245/50/R16, they have excellent grip and a great speed rating. Unless you are making ungodly amounts of horsepower, you will be fine with them.
If you want better traction, I would reccomend rear suspensiopn upgrades (Spohn products) before I tried to put more rubber on the ground. Make the car want to grip, and it will grip.
Hotrodboba400
Dec 10, 2019 07:07 PM
TheTraut88
Sep 7, 2015 05:22 PM
SG91camaro
Sep 5, 2015 10:27 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
