Roll bar install
Old Jun 18, 2004 | 01:21 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Roll bar install
I'd like to get and install a 8 point roll bar in my 82 Camaro. But all i have is 150amp arc welder. Am i screwed? Do you think that it would be possible to use this when welding to the floor?
Old Jun 18, 2004 | 06:14 AM
ede's Avatar
ede
i'd get a GMAW (mig) welder. you'll make it a lot harder on yourself with a stick (SMAW) machine. just so you know mig is arc welding as is tig and stick along with a few other processes.
Old Jun 18, 2004 | 11:38 AM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Sorry i should have said stick welder. I know its really easy to get a good weld when welding thick stuff (>.08") How thin or what gage is the floor pan?
Old Jun 18, 2004 | 11:44 AM
mykxt202's Avatar
Car: 82 z28
Engine: 400ci 450hp
I just put a 10pt cage in my 82z and used a mig and still had some trouble with blowing out the floor in areas where there was some rust. Your stick will do fine for welding the pipes together and onto the plates but I wouldn't use it from the plates to the floorpans
Old Jun 18, 2004 | 11:50 AM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Do you think i could get away with some 5/64 (.078") electrode?
Old Jun 18, 2004 | 12:15 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Maybe I don't remember right, but doesn't the NHRA rulebook say you can't use stick to weld the cage?
Old Jun 18, 2004 | 12:52 PM
ede's Avatar
ede
the smaller rods don't really make it easier to weld. the ideal diameter is 3/32 or 1/8 it gets harder to use going up or down from there.
Old Jun 23, 2004 | 02:03 PM
PhilM's Avatar
Car: Accepting applications...
Apeiron, you have remembered correctly. NHRA requires MIG or TIG for all welds.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
crazynights
Aug 21, 2015 06:53 AM
Dialed_In
Aug 20, 2015 01:45 PM
