Tire and Balance Question
Old Jun 28, 2004 | 11:06 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Can a tire/wheel combo be balanced and still have a slight wobble?
JamesC
Old Jun 28, 2004 | 11:27 AM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
Transmission: DYT700R4 custom inerts and conv.
Yes. A wobble is not imbalance, just imperfection of looks.
Old Jun 28, 2004 | 11:30 AM
JamesC's Avatar
Will this slight wobble affect the ride quality?
JamesC
Old Jun 28, 2004 | 12:15 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
It should not. If something is wobbling that you can feel while driving, get your tires spin-balanced again. If that doesn't work, then look to your ball joints and steering components (tie rods, centerlink, idler/pitman arms..)
Old Jun 28, 2004 | 01:34 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: Tire and Balance Question
Originally posted by JamesC Can a tire/wheel combo be balanced and still have a slight wobble?
JamesC
Yes.
I had some tyres go out of round. They were balanced fine. However, the tyre literally was not round. You could jack up the front of the car, spin a tyre, and if you watched the tread at the bottom, it moved up and down as the tyre spun. I got them warrantied out and put Michelin Pilot XGT H4 235/60's on the car. They are tonnes better.
If you bought them (have receipt) and they are doing this, have them warrantied out.
Old Jun 28, 2004 | 03:50 PM
Car: 1997 Corvette
Ah yeah, that's true too, forgot about tire out-of-roundness. Should be covered by manufacturer warranty. In any case, it wouldn't hurt to check out your steering and front suspension just to make sure everything is okay up there. When I bought my car, the driver's side outer tie rod end was VERY bad. In fact, once I removed it and played with the joint a little bit, the socketed ball actually came right out. All that needed to happen was for the end to turn just a tad, and I would've been in a huge mess. Anyways, I've replaced that tie rod end, my centerlink, and my idler arm all for under $100, and had a shop change a balljoint for around $100 as well. Car is tons better now after that, new tires, and an alignment.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
LT1Formula
Nov 16, 2015 01:13 PM
redmaroz
Aug 16, 2015 11:40 PM
cRoe4
Aug 7, 2015 08:46 PM
