supension upgrades worth it?
Car: 87 iroc
Engine: mild 350
Transmission: 350 turbo
what would it be worth in the 1/4
with the big rear sway bar like 24mm?? the ws6 ones
boxed lower control arms with aluminum bushings
lca brackets
will that stuff really make a big difference or am i wasting my time and need to go to ladder bar or something?
lca brackets
Car: 4
Engine: 6
Transmission: 5
The big payoff items are LCA lowering brackets and better LCAs; and of course SFCs. After that, for track-only type use, air bags in the springs.
Don't screw around with "boxed" stock control arms.
Car: 87 iroc
Engine: mild 350
yeah iam making another set from steel, and thats why i woudl be making aluminum bushings, haha, due to the fact i got no money ot buy poly's so ill jsut make them on my lathe
does this help suspension much either, raising your torque arm angle to 3 degrees?
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Car: 87 iroc
Engine: mild 350
really! i heard the more angle u runm the better traction u get, i played around wiht it and it changes your suspension by alot jsut by chaning the angle. i seen a ls1 camaro, all he did was lower control arms, and changed torque arm angle to 3 degrees and it brought him to a 1.7 60 ft time
to me, that is damn good but rememeber its a ls1
Car: 4
Engine: 6
Transmission: 5
Changing the torque arm angle does not affect traction. All it does, is to set the pinion such that when power is applied, the angle (which always changes slightly) becomes as close to 0 as possible.
Don't believe everything you hear..... for instance, I heard once that the Earth is flat. Didn't make it so.
And in the case of the guy with the 1.7s, did he try any other pinion angle? How does he know that where he has it is optimum? How does he know that he might not shave .1 off of it by setting it correctly?
dbrochard
Sep 25, 2015 04:56 PM
