Shock Absorber Bushings
Car: 82 Camaro; in process of resto
Engine: 350 4bbl.
Transmission: 700R4 with B&M Lockup
Axle/Gears: Moser 28-spline axle; 3.23 gears
I bought a set of KYB Adjustable shocks and put them on...and I squeak on the passenger rear. The nuts on both sides are torqued to spec (20 inch pounds, if I recall), and the rubber bushing is compressed to about the size of the washer.
I did the driver's side, and a friend did the passenger side. Upon inspection, the squeaky side is assembled wrong--
NUT
NUT
WASHER
BUSHING
-------------------------(Car)
WASHER
BUSHING
I tried to correct is, but when I put it in the right order, I don't have enough thread up top to start the nut. I think I may have the wrong bushings?? I've looked all around online & could only find some energy suspension shock bushings for ricers:
http://www.energysuspension.com/sk_bsp1.html
Would any of these work, or can anyone recommend a place where I can get shock bushings?
NUT
NUT
WASHER
BUSHING
WASHER
BUSHING
LT1Formula
Oct 8, 2015 08:34 PM
