tie rod sleeve
Old Jul 10, 2004 | 08:01 PM
FirebirdNYC's Avatar
Car: 1990 firebird
Engine: 3.1 v6
tie rod sleeve
it doesnt look that hard to me to replace, but is it? , im guessing i would need another wheel alignment, mine is bent and im replacing them both with moogs
Old Jul 10, 2004 | 08:06 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Easy, off with the old, on with the new. You could measure the length the tie rods with the old sleeve, then install the new sleeve and adjust to you get that same length. But if its bent now, you'll still need an alignment.
Old Jul 10, 2004 | 09:36 PM
Car: 1990 firebird
Engine: 3.1 v6
okay cool, i just wanted to make sure that one problem didnt lead to another , lets hope those 14 yr old bolts loosen up
Old Jul 10, 2004 | 10:33 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
I just replaced mine with solid aluminum sleeves. First i just measured the old ones, and replaced them the same. Or close to the same i adjusted the for a little more toe out, for better AutoX handiling. I used a homemade pickle fork to take off the ball joints.
Old Oct 9, 2004 | 02:53 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
how do these freakin tie rod adjuster sleeves adjust??????? i did some front suspension work and now one tie sticks out crooked compared to the other. i know if i could adjust the tie rods it would fix it until i could get it aligned but i can get the sleeves to move. is there a trick, i loosened the clamps that hold it in place but it still wont budge...im at a loss!
Old Oct 9, 2004 | 10:58 AM
Goumba T's Avatar
Car: 1990 TA
Engine: LB9 305
Transmission: 4L60
Some have ends you can put a wrench on. If not, you can stick a screwdriver in the slot and turn it (be careful not to distort it; if it doesn't turn easily, STOP).
Next time it will be easier to do it off of the car. Compare the length to the old one and just turn the tie rod end(s) till the length matches.
Ed1LE
Sep 30, 2018 09:14 AM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
