which rear swaybar to use?
Car: 91 Camaro RS
Engine: SBC
I was in the junkyard today and scored a 34mm front and a 21 and a 24 mm rear swaybar. The 32/21 set came off the same car the 24mm was off an IROC. I plan on using them on my 91 RS project which I am using eibach prokit springs and KYB AGX shocks and struts on (I know KONI or Bilisten are better but I got them on the cheap so I cant complain
). My question is which rear sway bar would be the best to use. The car was built for the street /strip and to handle. I didnt build it to be the best for any one thing but to do it all well. I like to drive it agressively on the highway from time to time and maybe try my hand at some roadcourse driving. I dont usually push it to its limits but I would like to know if I did it would handle the best it can. I have tubular LCA's, ADJ panhard bar, BMR ADJ torque arm, and LCA relocation brackets on it as well.
thanx
Doc
). My question is which rear sway bar would be the best to use. The car was built for the street /strip and to handle. I didnt build it to be the best for any one thing but to do it all well. I like to drive it agressively on the highway from time to time and maybe try my hand at some roadcourse driving. I dont usually push it to its limits but I would like to know if I did it would handle the best it can. I have tubular LCA's, ADJ panhard bar, BMR ADJ torque arm, and LCA relocation brackets on it as well.thanx
Doc
Car: 4
Engine: 6
Transmission: 5
I'd try the 32/24 combo first. That should be neutral coasting through corners, but maybe a bit loose (tail happy, oversteer) especially on the brakes. Try that and if it's too loose try the 34/24 combo. Anything with the 21 rear is going to understeer heavily.
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
I also recommend the 34/24 set as that's what my RS has now. A lot of Auto-X guys choose to run a smaller rear bar (IE-21mm or so) to help loosen up the rearend and keep the rear tires planted in the corners, and I assume this would hold true on the roadcourse as well. It's not that hard to swap a rear bar so play with them and see what you like. I have a 36/24 on my Iroc and 34/24 on my RS and both handle like mad but can get a bit loose in corners if it's a bit bumpy.
Ed
Ed
Car: 91 Camaro RS
Engine: SBC
So what im gathering is the 21mm bar would be better for the everyday street driving where the roads can be less than smooth.
So if I decide to push it alittle hard on say an highway offramp where it could get a bit bumpy the 21mm would keep the rear tires planted. Then I would switch to the 24mm when I do any type of competitive driving on a course. I will test them both and see what happens but thanx for your input. Thats why I love this board. I ve learned tons about my third gens and probably would have made some bad choices along the way if I didnt have you fellow third gen enthusiats to learn from. Thanx doesnt seem quite enough for what Ive learned, but since Im broke from my 2 projects it'll have to do...lol
Car: '87 Cam RS V6
Engine: Top Secret
Transmission: DYT700R4 custom inerts and conv.
With your car and setup (Shocks, springs) I would definately use the 24 bar without SFC's, and the 21mm bar with SFC's.
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
