Passenger Front Wheel Cracked
Old Jul 12, 2004 | 07:24 PM
IrocZed's Avatar
On Probation
Car: 03 BMW Zed4, 87 Camaro IrocZed 305 TPI
Engine: 2.5 I6, 305 TPI V8
Transmission: 5 spd., T700R4
Stress Fracture perhaps. But the stress cracks has spread evenly and two of the spokes are on the verge. It's a 87 5.0 TPI IrocZed.
I did not have any luck trying to find a replacement front wheel . Local junkyard and used wheel reseller have only rears (for 85-87)16"ers.
Can I use a 88-92(Firebird or Camaro)16" front wheel . It will look different (88-92 Camaro has a lip) but will it be the same, weight and offset wise.
Another quick question. I have been able to locate 15"ers in the same style so do I have this option of going for a temp 15" wheel at the front. Will it clear the brake and rotors/calipers.
Old Jul 17, 2004 | 09:05 AM
Vader's Avatar
You can use the T/A front wheels. You can use any wheel with the correct bolt pattern, a 0"/0mm offset, and adequate caliper clearance.
Moving...
Frozer!!!
Jan 19, 2024 04:55 PM
B_Dubya
Aug 26, 2015 05:09 PM
kah992
Aug 19, 2015 02:55 PM
wruiz
Aug 11, 2015 02:59 PM
