89 Turbo brake question
Old Jul 20, 2004 | 09:16 PM
AUTOGON350's Avatar
Car: 93 S10 blazer
Did all of the turbo TAs come with 1LE brakes? There was no 1Le on the RPO sheet but they look like the 1LE brakes. My dad just bought one and there seems to be a large amount of slop in the calipers. You can shake them with no effort. Feels like bolts are missing or something. I think something is wrong with them. Also are there some kind of pins that guide the calipers like on the non 1LE brakes or do they just float?
Old Jul 20, 2004 | 10:10 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
The rear will have "1LE" spec calipers but all of them '89-up got the rear PBR calipers. Look at the fronts...If they're aluminum, it's a 1LE car. But maybe all TTAs got the 1LE stuff...I dunno.
Ed
Old Jul 21, 2004 | 03:18 AM
jlarsson's Avatar
Car: 1989 TTA
Engine: 3.8L Turbo V6 - VIN 7
Transmission: 200R4
All 89 TTA's have the 1LE breaks front and rear. You can get rebuilt calipers from your auto parts store, just ask for the high performance once for our cars or the Corvette.
Old Jul 21, 2004 | 08:31 AM
ebmiller88's Avatar
What he said. There's usually a higher price for the 1LE calipers but the C4 HD (J55) calipers will fit just right and work fine.
Ed
Old Jul 21, 2004 | 04:49 PM
AUTOGON350's Avatar
Car: 93 S10 blazer
Thanks for the info.
I can really shake them around by hand. Probably a 1/4 inch or so in every direction. Should there not be that much play in the caliper? would the fact that the pads are worn out cause a lot of play in them or are they bad? Most of the places I have checked have the calipers for about 120per side. Does this sound about right?
Old Jul 21, 2004 | 04:52 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
There is a single pin at the bottom held in with an E clip. At the top the ears on the pads slide in a groove in the caliper bracket
Old Jul 21, 2004 | 04:54 PM
jlarsson's Avatar
Car: 1989 TTA
Transmission: 200R4
If you lightly press the brake pedal do they grap the rotor or are they still loose? If they are still loose I say the pistons are stuck in the bore.
Old Jul 21, 2004 | 05:56 PM
ebmiller88's Avatar
Instead of buying new ones, just rebuild them or shoot them to me and I'll do it for ya.
Ed
Old Jul 22, 2004 | 01:57 AM
BretD 88GTA's Avatar
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
The loose fit has nothing to do with the calipers. It's how the brake pads fit into the carriers. If the the tolerance is loose, then the caliper/pad assembly will shake or rattle.
I'm using the EBC Greenstuff pads and I massgaed them a little becuase I didn't like their build quality. This made them operate smoother, but also created a slightly loose fit.
Going forward is fine, but when backing up and I hit the brake pedal you can clearly hear and feel the calipers move. It's really no big deal though and I'll correct it with the next set of brake pads.
Old Jul 22, 2004 | 05:47 AM
Spdfrk1990's Avatar
So the c4 HD calipers are cheaper and exactly the same?
Old Jul 22, 2004 | 04:21 PM
AUTOGON350's Avatar
Car: 93 S10 blazer
There is no slack when the pedal is depressed. Sounds like this slop could be normal. the pads are pretty bad looking. I will get some new pads and probably the rebuild kit for them depending on the slop with the new pads. The way the assembly looks it seems like the movement was not a problem but I figured I would check.
Thanks for the responses
Under normal driving conditions is there any reason that EBC greenstuffs would not work with parts store replacement rotors?
Frozer!!!
Jan 19, 2024 04:55 PM
Terrell351
Jun 13, 2021 01:13 PM
Vintageracer
Jan 10, 2020 05:33 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
redmaroz
Aug 16, 2015 11:40 PM
