Preparing for 305-350 swap
Old Jul 22, 2004 | 06:09 AM
MuscleMadness's Avatar
Car: 1989 Trans-Am
Engine: 305 TBI
Transmission: 700-R4
What suspension mods are a must to swap a 305 with a 350?
Is there an aftermarket driveshaft drop guard to protect from your front shaft dropping or is that something I'd have to fabricate?
Old Jul 22, 2004 | 03:44 PM
DeWynter's Avatar
You dont have to chage any springs or shocks to go from 305 to 350
Old Jul 22, 2004 | 03:59 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
Originally posted by DeWynter
You have to chage any springs or shocks to go from 305 to 350
WTF, suspension is the same regardless of hte engine size.
you DON'T have to change anything.
Now, if you want to take advantage of the power, instead of just spinning the tires, you should look into rear suspension upgrades.
Old Jul 23, 2004 | 07:17 AM
MaroNut383's Avatar
Car: sc
Engine: 383carbed
Transmission: th400
Axle/Gears: 4.11 12 bolt
such as...........???(takes out pen and pad)<<<<.
Old Jul 23, 2004 | 07:37 AM
Dewey316's Avatar
Car: 1990 Camaro RS
I assume you are talking about rear suspension upgrades?
Although a search would yeild this information, I have nothing better to do right now (I am at work. )
1) FIX any worn parts, this will include, mounts, bushings, ect. It does not good to modify a broken car.
2) shocks. orget bolting anything on, a good set of shocks/struts are the BEST thing you can do as a mod. these will depend on how you are going to be using the car
3) Tires. The power has to go somewhere, this is you only contact point with the ground.
4) Geometry. this needs to be spot on. An adjustable torque arm (for adjusting pinion angle) and LCA relocation brackets. It does no good to through other parts on, if your geometry is no conducive to traction.
5) springs/sway bars. At this point, you really need to detmine exactly what direction the car is taking, for a track only car, this would be drag springs, no front sway bar, VERY large rear bar.
5) LCA's. Yes, these are LAST on my list. everything else is now working for you, you can strenghten these, and take out the deflection. if you do these first, all you are doing is transfereing more power that cannot be used.
6) PHB. for traction, this does nothing. if you like turn, the list looks diffrent and this is towards the top. all the PHB is, is a lateral support device, it will not effect forward traction.
Hope that helps.
John
Old Jul 23, 2004 | 11:23 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
First before you do anything get some SFC's. Do a for them, you will find all the info you need.
92camaroJoe
Jul 29, 2023 07:57 PM
theshackle
Aug 22, 2015 06:52 PM
g.l.mos
Aug 22, 2015 12:02 AM
Hello, Michael
Aug 20, 2015 03:19 PM
92camaroJoe
Aug 13, 2015 06:07 AM
