Questions about Earl's SS lines...
Old Jul 26, 2004 | 03:06 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
What part of the lines do these replace? Only the rubber lines from the hard lines to the caliper?
Also, if I'm going to an LS1 rear, what brake line kit should I order, or would I only be able to use his lines for the front brakes?
Old Jul 26, 2004 | 07:04 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
Yes, they replace the rubber hoses that go from the hard line to the caliper. And yes, you'll only be able to use the front pair for your application. However, they do make 4thgen lines as well- maybe you can get lucky somewhere.
Old Jul 26, 2004 | 10:00 PM
Car: 1997 Corvette
Does Earl's have their own website that I could contact him at for a custom package?
Old Jul 27, 2004 | 01:53 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
You can call and talk to one of the tech guys and they can make whatever lines you need.
http://www.holley.com/HiOctn/ProdLine/Earls.html
You can use the 3 rear lines from P/N 28A190 on your LS1 rear calipers.
Ed
MustangBeater20
Oct 29, 2022 09:20 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
