opinions on alignment after new struts
Old Jul 28, 2004 | 09:02 AM
90 Formula's Avatar
Car: 90 Formula, blue/silver
Engine: 305 TBI
Greetings, gearheads. I've been away awhile. Anyway, what are your opinions on getting an alignment after I get the new front struts on without disturbing the top strut mounts? Yes? No? Doesn't need it? Got a 450 mile road trip in two days and will not be able to get it into an alignment shop before then.
Old Jul 28, 2004 | 09:36 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
get an alignment. there can be variations in the stut, so your alignment may be off. it should remain close. but you never know.
Old Jul 28, 2004 | 10:55 AM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Toe and go. You can use a tape measure to check and see if your toe is ok. It should point slightly in. Thats the alignment angle that will cause the most tire wear. Then when you get back take it to a real alignment shop.
Old Jul 28, 2004 | 10:58 AM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
Transmission: DYT700R4 custom inerts and conv.
You're just replacing old struts with new struts? You should be fine without and alignment. A test drive does wonders in decision making.
Pac J
May 17, 2020 10:44 AM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
Ed1LE
Sep 30, 2018 09:14 AM
LT1Formula
Oct 8, 2015 08:34 PM
meeklay812
Oct 1, 2015 03:46 PM
