Camber with lots of lowering?
Old Jul 31, 2004 | 10:21 AM
shr00m's Avatar
Car: 1992 Jade Green---Trans Am Converti
I'm running the ground control adjustable springs all around with KONI yellows. I've got about 1.25" from top of tire to bottom of fender. Probably almost 2" of drop. I will be going lower when I get around to removing the rear isolaters.
Now, the fronts visually have a lot of negative camber due to the
natural increase as the suspension gets lower. What's the proper way to set it? Do I need to set it back to a more reasonable -1.25 or leave it as is? Seems that right now, right before bottoming out I'll still be at the same camber as before, but most normal driving will have an increase in camber, as it's like a stock car in a constant semi-squatted position. But if I set my at rest camber to normal, I'm losing out on the increased MAX camber close to bottoming.
Hmm..
PS, car is mostly fun/hard street driving, occasional autocross. Until I find a cage that doesn't kill the vert's look, I won't be road racing.
Kevin D.
Old Jul 31, 2004 | 11:48 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
well, since i am sure the springs are much stiffer now, so you will have less travel undercorner, so you camber change will not be as much. you may need play with what works out best with your exacty combo. I would set it to about -1* and see how you like it..
Amillionoh7
May 24, 2020 08:01 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
deracer
Apr 11, 2016 12:04 AM
Street Lethal
Aug 14, 2015 08:25 PM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
