New springs? struts?
Old Aug 1, 2004 | 01:16 AM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
When I hit dips at high speeds my car tends to scrape a tad (my exhaust is low). Is there something I can do to stop this besides slowing down? Is it more fault to my springs or my struts? Both need to be replaced- my springs are almost 130k old and the struts are over 30k. I have new struts but I'm afraid to deal with them, because everyone said they're a PITA.
Which brand of springs is stiff enough for me, that won't lower my car? I want some tough racing spring for a low price. What should I look at?
Old Aug 1, 2004 | 04:06 PM
MdFormula350's Avatar
stock replacement springs
http://www.spohn.net/product.cfm?productid=1404
i didnt think front struts are not that hard to install.
u might as well do both at the same time.
Old Aug 2, 2004 | 10:44 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
The fronts are a PITA because you are afraid that you are going to get smashed in the face by the spring. It sounds like you have worn springs as much as struts/shocks.
Old Aug 2, 2004 | 09:49 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
I'm on the hunt for some cheap stiffer springs, rather than the MOOG OEM replacements. Thanks anyway to MdFormula350 though. I was worried about lowering it (as Eibachs do 1") but people say as long as they're considerably stiffer it won't scrape. I'm still uncertain but I'd rather have a stiffer body and suspension than a mushy soft ride.
Who makes decent springs? How long do springs usually last?
Old Aug 2, 2004 | 10:12 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
I scraped about the same with the stock springs vs the sportlines. The again my ride height really didn't change because I went with a much bigger tire. My center of gravity did change however, which is always a good thing. I would look at BMR, the ProKit, or Hotchkis if you want sligth drop with a half way decent ride.
92projectcamaro
Dec 8, 2015 12:25 AM
Antips16
Oct 30, 2015 06:42 PM
Thirdgen89GTA
Oct 19, 2015 09:27 AM
92rsvortec350
19
Oct 9, 2015 09:39 AM
Dragonsys
Sep 25, 2015 03:51 PM
