Tires rubbing
Old Aug 5, 2004 | 11:28 AM
MuscleMadness's Avatar
Car: 1989 Trans-Am
Engine: 305 TBI
Transmission: 700-R4
Tires rubbing
I have 15" wheels with mastercraft 235/60/15's and when i turn sharp the tire rubs on the back of the wheel well...
How the hell would I ever fit 16's or 17's on there without clearance problems?
Old Aug 5, 2004 | 11:39 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
16 or 17 would be the diameter of your wheel, it doesn't have much to do with the overall size of the tire, which is what makes it rub or not.
I have 235/60R15s on my car with 1LE fronts and no problems with anything rubbing.
Old Aug 5, 2004 | 03:52 PM
91Z-TheReaper's Avatar
Car: 88 IROC
Engine: 350 L98
Transmission: T5 - 5 Speed
I'm clear but
I too have the 1LE Setup. I have no problems with my 16's -
BF Goodrich Comp TA 255/50/ZR16
The only problem I ever have is bouncing the tire off the upper wheel well - I'm lowered 1.75" in the front...
Old Aug 5, 2004 | 06:40 PM
Car: 1989 Trans-Am
Engine: 305 TBI
Hmmm, so are my tires just too big then?
Old Aug 6, 2004 | 11:41 AM
92RS3.1L's Avatar
Car: 91 Z28
Engine: Rebuilt and modified 350
Transmission: rebuilt T-5
I have the same problem too! Only my tires are 215/65R/15's. They were the tires from the rear that I put infront when I replaced the rear tires. They are the same size as the old ones, but now they rub. I DID get new wheel bearings and tie rods, if that makes any difference.
Old Aug 6, 2004 | 04:54 PM
Car: 1989 Trans-Am
Engine: 305 TBI
Thats funny, I replaced the rears on mine and put the new ones on the front, they never rubbed before i did that. Im gonna have to go check the size again to see if theres a difference.
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
MrPackstin
Oct 25, 2017 08:09 PM
skirocz28
Members Camaros
Nov 12, 2015 07:52 PM
Vincent135
Sep 28, 2015 10:50 PM
