Spent $300 at Spohn today.....
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
I finally put a bmr wonderbar - which is basically the same as the spohn on - last weekend. Man, world of difference in front end. I felt that more than I felt the GTA swaybars. Cant wait to get bilsteins and stb, it'll be sick.
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
Haha...you guys don't even know what expensive shipping is haha. THe panhard bar ALONE would probably cost about $30-40 for shipping. O_o Shipping for one of their roll cages cost around $198.
I had an aluminum driveshaft shipped across country to my girlfriends house for under $10 UPS ground. How much bigger can a panhard bar be? Do not misunderstand, I do not blame Spohn. I blame the greedy shipping comapnies who delivered broken boxes days late.
Car: 1999 Saturn SL2
Engine: 4 cylinder
Transmission: 4-speed automatic
Good luck with the install. No better feeling than installing a great part on your car with your own two hands.
Let us know how much better your car feels after the install.
Car: 89 RS
Engine: 383 in building process
You use the bolts alrdy on the car for the wonderbar you have to order a bolt kit extra for the panhard bar if you want new ones which 1 did for my lca's too. The relocation bracket come with the neccessary bolts to install.
Car: 91 camaro rs
Do these have to be welded on?
Been following your cars progress for a long time FLYINLOW, fantastic work. That car has come a LOOOOOONNNGG way in a short time!:hail: :hail: :hail: :hail: :hail: :hail:
Good luck with the rest.
Andy.
Andy.
Andy.
Andy.
Car: 82 Trans Am
Engine: LTX
Axle/Gears: 3.42 strengthed 7.5 inch
don't know the specs offhand but take one of the panhard bolts off and to your local fastener shop.. don't go to the hardware strore go to a shop that specializes in only fasteners that way you can get a better grade bolt.. I had to do that for my upper rod, it had to have the bolt sawed off..
Save up for the xmember and torque arm combo next, that is my next wishpart.. the best setup out there..
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
very nice man!! im also suprised and impressed how nice you car is and how much youve done to it in jsut a few short yrs.
btw: i know that lca brackets fix the suspension geometry but what do they actually do as far as feel, performance etc??? better traction perhaps?
and do they HAVE to be tig welded? ive got a flux core welder ive used on my exhaust, headers etc will that work?
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Shipping LCA's, torque arm, panhard bar, and LCA braketsand it was like 50 some dollars from spohn. I ended up going with BMR and shipping was 15 bucks.
Guest
Posts: n/a
FLYN if i were you i would send those LCA's from there back ASAP!!! its going to cost you like 200$ in labor just to put those damn things on.
i was at Dyno Dons shop the other day and he showed me the difference between those and BMR's.. GET THE BMR"S!!!!!! you have cut parts, drill, hack, and pretty much do everything to get those damn things from Spohn on. the design is not as good as others. infact Don wont even go through the hassle of installing those from Spohn..
Email him and ask him, he'll tell you like it is. and for kicks, when they come in the mail, read out loud the directions on how to install them.. its pretty funny.
The problem with Tig welding, is its kinda difficult for most people to do, equipment is expensive and its in a bad spot to do it.
I mig welded mine into place, if you need help, I will mig it into place for you if you let me take the car for a spin.
no green
Jan 9, 2016 09:22 PM
Royal_Z
Sep 30, 2015 08:45 PM
