Anyone ever heard of 16" tires on 17" rims?
Old Aug 10, 2004 | 11:39 AM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
Okay, I wanna pick up some new rims...probably not until next spring unless I come across a really good deal, but anyways..
I remember reading something at Suburban Tire one time while I was there with my last car, and in the brochure, it said something about putting a tire that is 1" (rim size) smaller onto a rim to give it a more "aggressive" look and something about performance (probably less sidewall flexing).
Anyways, I was curious if anyone else has ever heard of this, and do you think it would be okay to put my Kumho Supra 712 P245/50ZR16 tires onto 17" 4th gen rims?
Old Aug 10, 2004 | 11:54 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You read wrong. It cannot be done. Maybe they were refering to the overall tire height being 1" shorter.
Old Aug 10, 2004 | 12:03 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
The were referring to oversizing or using bigger rims and tires then the factory. What you said can't be done.
Old Aug 10, 2004 | 12:07 PM
Car: 1997 Corvette
Hmm...I'll have to run over there one of these days and see if they still have the brochure. I didn't think it made much sense either when I read it. I just remembered it a little while ago and figured I would ask about it because I didn't think it sounded too viable either.
Old Aug 10, 2004 | 08:06 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
You may have read it wrong. It may have said Plus 1 size which is going from a 16" rim and tire to a 17" rim and tire and keeping the tire height the same.
This is from discount tire direct,
" Plus sizing is one of the easiest ways to achieve enhanced performance and improve the appearance of your vehicle. In the example above, a 15x7 wheel with a 205/65R-15 tire is considered the O.E. (original equipment) size. Converting to a plus 1 size would mean increasing the wheel diameter by 1" (16x7.5) and selecting an appropriate tire to fit (225/55R-16). Likewise, moving to a plus 2 fitment would result in a 17x8 wheel and a 245/45R-17 tire. It is important to note that although the wheel diameter is increasing, the overall diameter of the tire remains consistent. As a matter of fact, this method typically maintains the overall diameter of the tire within +/- .04 inches. This is crucial to preserving the speedometer reading and gear ratio.
A couple of things happen with the tire to increase performance when we begin to move into plus sizes. First, the tire is wider (section width) and therefore gives us a larger footprint. Second, the sidewall becomes shorter (aspect ratio) and more rigid. The two added together give better lateral stability and increased steering response."
Old Aug 10, 2004 | 08:27 PM
Car: 1997 Corvette
Aw damnit I'll bet that is it. LOL! I completely understand how that works, I've done the math a ton of times for my buddy's Nissan.. oh well..
Hotrodboba400
Dec 10, 2019 07:07 PM
birdman_29
Jan 7, 2017 08:24 AM
my86bird
Oct 23, 2015 12:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
