all new front suspension....
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
this winter i changed everything in the front of the car, and it rides like brand new now.....and it handles much better and launches even harder.
i used eibach drag launch springs, moog ball joints, new strut bearings, koni red adjustable shocks and struts, and energy suspension control arm bushings and sway bar links.
the car drives nice and smooth up past 150mph:lala:
and with a few twists of a **** the front end comes up like a **** at the track
Re: all new front suspension....
Is that a genuine 150mph?
Car: '91 Camaro RS
Re: Re: all new front suspension....
Originally posted by Dr G
Well done 383backinblack! One thing though, never mind handling like brand new - your car will now be Better than brand new! :-)
Re: Re: Re: all new front suspension....
i've gone over 170 in it lol
My problem at the moment is being stuck with a TH700-R4 that can't upshift to 4th at WOT. Just another part to replaced at some point I suppose. It is beautifully stable up past 140mph though.
Any chance you can let me know the rest of your cars modifications, cam choice etc? In this thread or by PM?
Thanks!
Car: '91 Camaro RS
Re: Re: Re: Re: all new front suspension....
Wow! Excellent! Has it always been a manual? Or did you change from an automatic trans? How does the top speed compare?
Thanks!
Thanks!
Car: '91 Camaro RS
Originally posted by iansane
For a second there I thought in your original shot you were holding the car up with that 4x4...
Car: 91 RS
Engine: 355
I'm in the middle of this suspension rebuild myself and I'm having trouble figuring out how i'm going to remove the old control arm bushings, would you be able to explain how you did yours?
Car: 91 Firebird Formula
Engine: For me to know.....
Transmission: and you to find out....
Dan
Car: 05' GTO
Engine: 6.0L
Transmission: A4
hey 383 did u notice any drop in those springs? does the car handle nicly in turns? becuz i got regular stock replacement springs from perfect circle suspention and things are just way to stiff. it handles sweet in the turns but killin me at the 1/4
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Originally posted by metalhead212121
You're gonna need a press. I ened up going to a machine shop and having them press the old ones out and having them press in Del-A-Lum Bushings. Supposedly they are better than poly bushing because you can grease these. I personally dont think they are any better than rubber but my car has a long way to go. So take my opinion for what its worth....(Project car with many many issues)
Dan
Dan
Originally posted by VILeninDM
How much was it to have them pressed out and in? I need to do all the stuff you did and more, so I am contemplating if it would make more sense in the long run to just buy a press.
Matt87GTA ~ Interesting tech info on those bushings! Thanks!
Dan
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
I made a little post about how to remove and install those bushings..
not qute del-a-lum, but the procedure would be pretty close I think..
https://www.thirdgen.org/techbb2/sho...hlight=bushing
came out to about $170.
I'll have to do all this stuff, then tranny rebuild and a rear-end rebuild.
Car: 1992 camaro rs
Engine: 346 ls1
Transmission: t56
Axle/Gears: strange 12 bolt 3.73's
have a quick question. what is the part number for those springs i was thinking about getting drag launch springs but cant find them. im going to the ls1 swap hopefully gotta see how funding pans out. and how much where they?
Car: 05' GTO
Engine: 6.0L
Transmission: A4
yeah i just noticed in Jegs they only sell the drag kit for 93-02 camaro's/firebird's. im really thinkin aboutgettin thing kit.
1Aauto
Sponsored Vendors
Aug 26, 2015 02:18 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
