Drum brake pad question
Car: 1989 Iroc Z
Engine: 5.7 TPI
I have a 1991 Z28, 350, auto and it has the Borg warner 3:23 rear end but has drum brakes on the rear.
The shoes are worn out and needs replacing.
What brand brake shoes should I go with that wont squill when braking and where do i get them?
Thanks,
BLURR
Thanks,
BLURR
So you are one of the lucky ones to have a drum brakes with your 350 (91 was the year GM had a disc brake supply problem)For your info the 3:23 ratio is a 10-bolt rear and not BW.
Check any Auto Parts store for the brake shoes, they are a common part. There are not any performance drum brake shoes made now for all I know. The last one I used were semi-metalic.
Car: 1989 Iroc Z
Engine: 5.7 TPI
Eric-86sc
Apr 3, 2016 03:52 PM
