can someone please tell me how to fix this pics inside
Old Aug 16, 2004 | 09:02 AM
91rsowner4life's Avatar
Car: 1997 S10
Engine: 4-Cyl 2.2 Liter
Transmission: Automatic
can some one tell me how to fix this and what part i need to buy and the part name please. heres some pictures
Attached Thumbnails can someone please tell me how to fix this pics inside-under-my-car-left1.jpg
Old Aug 16, 2004 | 09:08 AM
Car: 1997 S10
heres the other side
Attached Thumbnails can someone please tell me how to fix this pics inside-under-my-car-1.jpg
Old Aug 16, 2004 | 09:34 AM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
Sorry to say the car is toast!....
Easy fix. Just go to any autoparts store and ask for a set of rear swaybar end links. They will come with new bolts/bushings.
If you cant just pull off the outside sleeve that is hanging there you probably will have to cut it off, just make sure not to damage the bracket that is bolted to the car.
Then just slide on the new end links and torque to 21 ft/lbs. Done.
They should look something like this new/ Just the white bushings will probably be black/blue/red.
Old Aug 16, 2004 | 10:24 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
when you goto the auto parts store, they will want to sell you stock replacement sway bar bushings.
if the guy hands them to you, take one out and squish it between your fingers.
its that soft.
in the computer, there should be a poly sway bar bushing option... get thoes... its about $12.
if its not in the computer, goto where they have them on the shelf, and match the center spacer height to the closest one on the shelf.
do all 4.. if the rear two are that bad, the fronts are probly just as bad.. you should notice a nice improvement...
Old Aug 16, 2004 | 03:38 PM
Car: 1997 S10
novass man i read that and i just about died when the page came up untill i read the other part of your post lol. cool thanks for the help i will fix it this weekend :lala:
Old Aug 16, 2004 | 04:56 PM
Car: 1997 S10
sorry i for got to say this. i saw that it was hanging down on both sides when i was getting my oil changed. i guess it came undone while i was driving. what holdes it up to the sway bar? will the thing that holdes it to the sway bar come with the $12 poly sway bar bushing option?
Old Aug 16, 2004 | 08:40 PM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
Yes, it is just a long bolt.
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
dibella989
Sep 1, 2015 04:12 PM
evan555222
Aug 22, 2015 07:14 PM
Thirdgen89GTA
Aug 20, 2015 12:11 PM
firebirdchick28
Mid-West Region
Aug 16, 2015 02:52 PM
