rear drum to disc brake
Car: 1985 Trans Am
Engine: Chevrolet 355
Transmission: Borg Warner W.C. manual cog
Axle/Gears: B W 9-bolt 3.45 Limited Slip
Does anyone know if the rear axle housings for drum (85)and discs (89) are the same so if one wanted to change to discs its a simple swap and would it be best to change proportioning valves?
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
To answer your question: No.
Search my man, search...
https://www.thirdgen.org/newdesign/t...reardisc.shtml
and
http://members.fbody.com/86firebird/ls1/ls1brakes.htm
There's more out there...
Ed
and
Ed
Car: 1990 Formula
Transmission: WC T5
Re: rear drum to disc brake
I put in a new 4 wheel disk 1LE
valve, however, my part # wont work for you because mine is a 90.
pics:
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
