Help with wheight change and stance
Old Aug 16, 2004 | 05:53 PM
BAD91CamaroRS's Avatar
Car: 91 Camaro RS 383
Engine: carbed 383
Axle/Gears: 3.42 posi
I need some advice from all of you third gen owners... My RS has a 4th gen rear with the eibach lowered springs. The problem is now that the front end is higher than the back because of my alluminum heads and i am also getting a fiberglass hood so it will be even more higher.. What could i do to raise it back up to a level state?
Old Aug 21, 2004 | 04:07 PM
FastZ28*84's Avatar
Car: 84 Z28
Engine: 72 350 .030 over
Transmission: 89 WC T-5
Do you have eibachs on the front aswell?
I have a similar problem. I have all stock springs and have aluminum heads, radiator, plastic headlights,and have stripped all the smog off. I also have a fiberglass hood to put on and my frontend sits up. I even cut a full coil off my front springs and it still sits up.
I would think we need a softer rate spring that is a bit shorter than stock. I do not know what springs to get. Maybe v6 springs?
Old Aug 21, 2004 | 04:09 PM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
Transmission: DYT700R4 custom inerts and conv.
Here you go-
http://www.colemanracing.com/section/index.htp?id=361
Old Aug 21, 2004 | 04:49 PM
92camarors5spd's Avatar
Car: 1992 camaro rs
Engine: 346 ls1
Transmission: t56
Axle/Gears: strange 12 bolt 3.73's
gabriel air shocks maybe? it lifted the rear of my 70 chevelle a good 3 inches higher than what it was
86CamaroDan
Sep 29, 2015 10:08 PM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
FormulasOnly
Sep 6, 2015 10:42 AM
luvofjah
Sep 3, 2015 07:08 PM
