Car Pulls Hard to the left
Old Aug 20, 2004 | 10:36 PM
1982Camaro383's Avatar
Question for you guys I have a 1982 Camaro and the car pulls extremly hard to the left. I replaced the pads, rotors, calipers, bearings & seals with new on both sides. Still have the same problem. Brake hoses are fine no leaks. Brakes have been bleeded. Any ideas would be greatly appreciated. Tire pressure is 35psi on all four wheels. Trying to get the problem fixed for the woodward cruise which is tomorrow. I am out of ideas what do you guys think.
Thanks,
Justin
Old Aug 20, 2004 | 11:05 PM
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
Alignment?
How is the treadwear on the front tires?
Old Aug 20, 2004 | 11:08 PM
Perfect no problems
Old Aug 21, 2004 | 09:12 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Swap the tires from side to side. See if the problems stays or moves.
Brake hoses don't fail by leaking; they fail by becoming blocked, by rusting from the inside. What happens, is that they rust all the way closed, and then when you step on the brakes, a tiny amount of fluid is forced into the calipers, but it can't get back out; so the failed brake stays applied 100% of the time, except maybe for first thing in the morning, until the first couple of times you use them.
Old Aug 21, 2004 | 09:31 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
If you still have the stock rubber brake hoses, that is your problem (age) replace with the SS brake hoses and that should cure the problem.
Old Aug 21, 2004 | 05:19 PM
craig's Avatar
Car: 86 camaro
Engine: 433 big block
Transmission: jw powerglide 5500 coan stall
Axle/Gears: moser9" 4:11 posi
i'll second the brake hose replacement. the inside collapses and acts like a check valve, not letting the fluid return.
1992 Trans Am
May 10, 2023 07:19 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mizz0313
Aug 12, 2015 06:45 AM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
