Need help fast
Old Aug 21, 2004 | 02:17 PM
Formula4Speed's Avatar
Car: 1990 Formula
Engine: 305 TBI (LO3)
Transmission: 5 speed manual
Need help fast
Okay guys, I installed a strut tower brace on my car and when doing so me or my friend unbolted the black cover on top of the driver side strut. I didn't realize it was unbolted so I drove and it popped off and to the side, now I can't get it to move to where it should be to bolt it back down. I tried jacking the car off the ground to get the pressure off of it but it still won't budge. Do I need to take the wheel off to fix this? If so I have a problem because there is one of those anti theft lug nuts on the wheel and I have no key for it. I really need to get this fixed ASAP.
Old Aug 21, 2004 | 02:34 PM
john5.7 87Iroc's Avatar
Car: An '87 Italian Retard Out Cruisin'
Engine: LS1 install in progress
Transmission: 4L60e
Axle/Gears: 9 bolt
edit: sorry, looked at the pic again.
Old Aug 21, 2004 | 03:52 PM
DSmith's Avatar
Car: 1989 Camaro
Engine: 383
try to put a longer bolt in it and pull it back in place that way
Old Aug 21, 2004 | 03:53 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
try jacking up car leaving suspension hanginf free, it will at least help
Old Aug 21, 2004 | 05:58 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Put a floor jack under the control arm, right underneath the spring pocket; that will lift the whole suspension up and take the force off of what you're trying to work on.
Jacking up the car and letting the suspension hang won't do it, it will all still be under spring tension.
InfernalVortex
Apr 20, 2021 11:31 AM
grngryoutmyway
Oct 18, 2016 05:48 PM
sreZ28
Oct 22, 2015 08:21 AM
Nervous2
Oct 8, 2015 10:53 PM
customblackbird
Oct 1, 2015 04:30 PM
