My experience with the wonderbar
Old Aug 22, 2004 | 06:04 PM
91FirebirdFmla's Avatar
Car: Green 1991 Firebird Formula
I just installed the spohn wonderbar on my car. It wasn't as easy as I anticipated. Although the holes lined up perfectly, there was a clearance issue with the lower mounts for the fan. I have the duel fan setup. This resulted in the fans both hitting the radiator slightly once I torqued the sway bar bushing bolts. To remedy this, I unbolted the fans and moved it slightly away from the radiator and all is well. The wonderbar is a great piece and I can definitely feel a difference in the way the car steers. I was just wondering if anyone else has had clearence problems with theirs. In all the pictures I have viewed, there is always pleanty of space for all of the components. My car was never, to my knowledge in any sort of front end collision.
Old Aug 22, 2004 | 09:44 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
the wonderbar is an awsome addition to any f body
Old Aug 22, 2004 | 10:56 PM
I agree 100%. It's just my particular install which makes me wonder whether something may have happened to my car or something else weird is going on.
Old Aug 22, 2004 | 11:15 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
nah with the double fans its always a pita. if all the bolts holes lined up properly then your car is fine
Old Aug 22, 2004 | 11:54 PM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
Where can I get the details on this product? "Wonderbar" search on Mamma.com loses for me.
Curious,
Old Aug 23, 2004 | 12:01 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
click on the board sponsers up top for tds they sell them. basically a wonderbar takes the stress off the steering box and makes both wheels turn together instead of making the steering box do it, tds went one step further in tying the front of the car together with their design.
basically its a must have for any thirdgen, along with sfc's
Old Aug 24, 2004 | 12:22 AM
Cadillac's Avatar
TDS Bookmark for the Wonderbar
Added to the list. Easy for a n00b to install?
~C
Old Aug 24, 2004 | 01:00 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
basically if you know how to use a ratchet you can do it. it took me 10 minutes to do, and that included getting it up on ramps.
you will notice the difference right off the bat
Old Aug 25, 2004 | 09:00 PM
Joez88Camaro's Avatar
Car: 1988 Camaro Sport Coupe Convertible
Engine: Your Momma
Transmission: I can go forwards and backwards
My contributing on the subject:
https://www.thirdgen.org/techbb2/sho...hreadid=250688
I tried to make it easy so that anyone doing a search would find it.
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
91 SrS
Oct 7, 2015 04:32 PM
jaridjohn
Oct 5, 2015 07:01 AM
mfp189
Sep 27, 2015 09:25 AM
