2nd Gen vs. 3rd Gen suspension
Old Aug 23, 2004 | 07:44 PM
Chet's Avatar
Car: GTA
What's the difference between the 2nd gen front suspension (1974-81) and the 3rd gen front suspension? Are any parts similar? I'm asking because I have a friend who wants to swap front springs with a pair from a GTA. He says they're interchangeable, anyone know for sure ?
Old Aug 23, 2004 | 07:48 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I can't see how anything would be interchangeable between the two.
Old Aug 23, 2004 | 08:08 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
they are 2 totaly different setups
Old Aug 24, 2004 | 07:51 AM
wilyk9's Avatar
Car: 85 Trans Am
Engine: 305 Carb
I have both, a 71 and an 85. Actually there is quite a bit of similarity, but not interchangeability. They both have a lower control arm with the spring between that and the 'frame'. Both use a steering gear box/tie rod setup. Big difference is the 2nd gen uses upper control arms and shocks while the 3rd gen uses a strut. I have to agree with the other responses, nothing is likely to interchange. Springs may fit, but even if they fit physically, what about spring rates? I have the 85 suspension apart right now, but not the 71, otherwise I would do a side by side for ya.
bjpotter
Jan 22, 2019 12:27 PM
cam-mike
Aug 24, 2015 07:23 AM
tricky1
Aug 23, 2015 01:17 PM
