Paint for brake pads
Old Sep 4, 2004 | 09:44 PM
25THRSS's Avatar
What type of paint should I use to paint the actual backing plates for the brake pads and shoes. Mine are red and I want to paint them black, but what will withstand that type of heat?
Old Sep 5, 2004 | 12:16 AM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
umm thats not paint it is anti squeek compound. it helps the padsfrom vibration and chattering noises/ if you put paint on em i'm not sure what the effect will be. you should use a high heat like engine paint.
Jeff
Old Sep 5, 2004 | 12:47 AM
25THRSS's Avatar
Jeff
UMM, what are you talking about? The backing plates on my pads/shoes are powdercoated red I believe. Where did anti squeek come into play here? I've painted the pads on my LS1 with caliper paint and they have started to bubble. What should I use?
Old Sep 5, 2004 | 07:24 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I used high temp engine paint from CarQuest. No problems. Check the pics, if you wish:
https://www.thirdgen.org/techbb2/sho...hreadid=246768
JamesC
Vintageracer
Jan 10, 2020 05:33 PM
Eric-86sc
Apr 3, 2016 03:52 PM
g.l.mos
Aug 22, 2015 12:02 AM
articwhiteZ
Aftermarket Vendor Review
Aug 18, 2015 07:26 AM
kyleb24
Aug 15, 2015 08:24 AM
