Brake noise - not squeeking
Old Sep 10, 2004 | 01:19 PM
kaupca's Avatar
Car: 92 Camaro RS
I get noise when I brake that is not the noise of squeeking brakes. It is kind of hard to put in words. Kind of like a whomp, whomp, whomp. I tightened up the pads on the calipers once and it quit for about 2 days. I have replaced the pads, calipers, brake hoses, master cylinder, ball joints, struts, strut mounts, inner and outer tie rod ends, springs, idler arm, control arm bushings sway bar end links and sway bar busings. What might be making the noise. It is quite annoying. Thanks
Old Sep 10, 2004 | 01:25 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
sounds to me as if you have warped rotors on the front .....
Old Sep 10, 2004 | 01:26 PM
CaysE's Avatar
Re: Brake noise - not squeeking
Originally posted by kaupca
...I tightened up the pads on the calipers once and it quit for about 2 days...
What do you mean by tightened? What did you do?
Old Sep 10, 2004 | 01:39 PM
THEGENERAL's Avatar
Re: Re: Brake noise - not squeeking
good question .....!!!!
Old Sep 10, 2004 | 02:17 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
:werd:
Old Sep 10, 2004 | 02:26 PM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
Transmission: DYT700R4 custom inerts and conv.
Are you getting any kind of vibration or shaking?
Old Sep 10, 2004 | 09:14 PM
kaupca's Avatar
Car: 92 Camaro RS
Tighten the pads
by tightening up the pads I mean bending the tabs to try and make the pads fit tighter to the caliper.
dbrochard
Sep 19, 2015 08:13 PM
lock1983
Brakes
Sep 9, 2015 09:08 PM
Randomtask2
Sep 7, 2015 05:06 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
