torque arm mount
Old Sep 14, 2004 | 09:44 AM
hoogabooga's Avatar
Car: '68 corvette '73 Corvette
Engine: 427 454
Transmission: TH400
torque arm mount
while replacing my transmission i found yhat the last owner welded the torque arm bracket to the trans. i found a bracket in a junkyard after a LOT of searching but the bushing faces the wrong way. my question is can i get a new bushing and drill out the rivets and install it to the same bracket or are the brackets different? local gm dealer has a new bracket with bushing but is expensive and will take 2 weeks.
Old Sep 14, 2004 | 10:10 AM
1983Fbody's Avatar
Car: transam, el camino
Engine: 415
You should be able to just switch the bushing, I would get a poly one from one of the aftermarket companys like spohn vs. paying a dealer price for a rubber one.
Old Sep 14, 2004 | 11:29 PM
hoogabooga's Avatar
Engine: 427 454
Transmission: TH400
thanks
Old Sep 15, 2004 | 09:02 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
hmm how did they ever get a steel bracket to hold to a alum housing? well mine is some type of white metal maybe not alum but it is not steel. what is your tail section made of?
jeff
morrow
Jan 13, 2024 12:29 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
angel2794
Sep 8, 2015 06:22 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
