WS6 Package
Old Sep 14, 2004 | 07:30 PM
forums_suck's Avatar
Car: 1983 Z28
Engine: 383
WS6 Package
Hi guys been pilfering a 1985 formula firebird at the local yunk yard for part to put on my 83Z28.The car had the WS6 suspension package,and im wondering if i should grab any of the suspension parts for my 83Z28.
Is it worth it?
Old Sep 14, 2004 | 08:40 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
The sway bars are worth it. They are about the best you can get for our cars.
Old Sep 14, 2004 | 08:52 PM
Car: 1983 Z28
Engine: 383
What about the springs are they pretty much the same?
Old Sep 14, 2004 | 09:16 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
They are different but noth worth it. Aftermarket ones are much better and chances are that these ones are worn out.
Old Sep 14, 2004 | 10:09 PM
Car: 1983 Z28
Engine: 383
Thats what i was thinkin theres not much of a spread between years in the two cars thnx
Old Sep 15, 2004 | 10:49 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Did they have Formulas in 85?
If the parts are cheap, grab them. Springs may be worn though.
Old Sep 15, 2004 | 11:57 AM
Car: 1983 Z28
Engine: 383
Not sure if its a formula the vin is 1G2FW87H9FL651304
Old Sep 19, 2004 | 01:24 AM
1tinindian's Avatar
Car: 1983 WS-6 Trans Am
Engine: 1999 L31 5.7 Vortec
Transmission: 5 speed
Axle/Gears: Auburn Limited-slip w/3:73 gears
Carfax shows that VIN to be a 1985 Trans Am with a 5.0 4bbl.
It may vary some in the suspention, depending if it was a WS-6 car or not.
Old Sep 19, 2004 | 01:42 AM
semiller26's Avatar
Car: 1986 Trans Am
just measure your bars and if the birds are bigger grab um up
Old Sep 19, 2004 | 11:25 PM
blackgold84's Avatar
Car: 1984 Z/28 Camaro
Engine: 350ci
Axle/Gears: 9" 3.73 spool
what semiller said, good bet they are bigger.
i found a front off of a formula and put it on yesterday, turns out its a 36 hollow and mine was a 32 solid bar, big diff in weight, and hopefully performance, i've got the poly endlinks for the front and rear did a short test but couldnt tell much
The bar wont be bigger than 36, i dont even think there was an after market bar that big. so get it if its bigger than your current one. If its hollow you have wieght savings right away, only down side is new bushings may be needed.
Old Sep 20, 2004 | 01:03 AM
leeperryracing's Avatar
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
Yup, the biggest and best sway bars for our cars comes from the ws-6 genre...36/24mm hollow bars, GRAB 'em, you can't go wrong.
Old Sep 20, 2004 | 01:36 AM
semiller26's Avatar
Car: 1986 Trans Am
My car has the 36 front 24 rear setup with the 550lbs springs. There is no 5.0 mustang that can keep up with me on Mt. Diablo
Old Sep 20, 2004 | 06:45 PM
Engine: 350ci
26MM?
is there a 26mm rear sway for third gens?
there is a guy im trying to buy one from and i dont know if its ligit, seems to me like the biggest offered was the 24mm, was there a 26mm bar rear ever?
thanks
-doug in texas
Old Sep 21, 2004 | 01:33 AM
joshwilson3's Avatar
Old Sep 21, 2004 | 01:36 AM
semiller26's Avatar
Car: 1986 Trans Am
No the biggest is 24mm but there are a few guys who said they have found 25mm solid bars on some junkyard IROC's. There are no 26mm bars though.
How do the Spohn sway bars compare to the WS6 sway bar package? Would it be worth it to spend the couple of hundred dollars on the spohn front and rear sway bars, or just get the sway bars from a WS6 car?
The Spohn bars are solid I believe so they would be heavier than the 36mm hollow bar.
Old Sep 21, 2004 | 05:39 AM
doc76239's Avatar
Car: 1989 FIREBIRD FORMULA WS6
Engine: TPI 305
cost
So you need to figure out if the cost of the sphons sway bars are worth all that extra money. I have an 89 firebird formula with the WS-6 suspension and I wouldn't change to aftermarket sway bars. Hope this helps.
Old Sep 21, 2004 | 08:14 PM
Engine: 350ci
i wanted sphon bars, i got a 36 hollow and went to it from a 32 solid and i love it, it still needs new bushings but it rocks, now for the rear im wanting a fat bar for drag traction, so a 1" sphon bar is for me, hope this helps.
Old Sep 21, 2004 | 08:29 PM
89Formula5.7's Avatar
Car: 89 Formula 350
Engine: L98 w/ Stealthram
Axle/Gears: 9 bolt 3.27
I am really happy with my stock WS6 sway bars. I added some poly end links, and wouldn't bother with shelling out cash for aftermarket ones.
Old Sep 23, 2004 | 01:12 PM
Old Sep 23, 2004 | 09:32 PM
Engine: 350ci
steering brace, aka "wonderbar"
wheels 16x8's
a good rear end, with disc's and better gears
any thing that looks better than the corelating part on your car
Ed1LE
Sep 30, 2018 09:14 AM
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
PurelyPMD
May 5, 2016 04:57 PM
jrdturbo
Mar 31, 2016 02:58 PM
Dragonsys
Sep 25, 2015 03:51 PM
