cutting endlink sleeves
Old Sep 26, 2004 | 09:34 AM
92RSMuscle's Avatar
i got new sway links because im putting new bars on my car, and it was mentioned to me by a GM master tech that with our style end links, you can hack an Inch, no more off the sleeve on both sides and as long as they are the same size that it will preload the swaybar and greatly improve handling, upon asking him if he has done this to anyones cars he said 'yeah we used to do it alot and people were thrilled' anyone else done this?
mike
Old Sep 26, 2004 | 10:49 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
why cut em you can buy anysize length that you want from energy suspension even pep boys have em all on the shelv.
as far as i heard is that the flat of the bar should be be level with the ground to be correct. now as for pre loading i have no idea. what would be the benifit or drawback and would that be lower than level i guess.
Jeff
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
loud91rs
Oct 5, 2015 10:05 PM
gord327
Oct 3, 2015 01:25 PM
