91/92 chasis refinements?
Old Oct 10, 2004 | 09:33 PM
camaro05's Avatar
Car: 91 Z28
Transmission: built 700R4
I was wondering if anyone had head that 92 camaros had some chasis refinements/changes from the 91 model, and if that statement was true? And if so what were they? I have searched but didn't come up with anything helpfull.
Old Oct 10, 2004 | 11:51 PM
Duck's Avatar
Moderator/TGO Supporter
Car: 87 IROC 92 Z-28 91 Ragtop
Engine: 5.7
Transmission: 700-r4
GM made the suspension softer for the 91-92 Z28s. Having both the harsh IROC and 92 Z28, I prefer the IROC for smooth roads and the 92 for cratered city streets. I think the earlier suspension is more accurate fir high-speed driving, but you gotta be hard-core to live with it. The 91-92s are much more civilized.
Personally, I don't consider the softer suspension an "improvement" but my wife sure does!
Old Oct 11, 2004 | 01:07 AM
25THRSS's Avatar
I remember hearing something about the materials they used to hold the chassi together being better in 92, but I can't remember specifics right now.
Old Oct 11, 2004 | 01:24 AM
Morley's Avatar
In 91-92 they supposedly used sound deadening material throughout the cars to help reduce squeaks and road noise.
Old Oct 11, 2004 | 05:29 PM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
They started using bonding agents in the unibody in addition to the spot welds.
Old Oct 11, 2004 | 06:20 PM
camaro05's Avatar
Car: 91 Z28
thanks for all the info everyone, hey 406 is that for 91 and 92 or just 92? thanks
Old Oct 11, 2004 | 06:34 PM
406TPI's Avatar
Car: 1985 IROC-Z
If memory serves me correctly, they started doing it in 91
Old Oct 11, 2004 | 07:27 PM
305RSlc's Avatar
Car: 1991 Z28 Camaro
Transmission: 700R4 that will magically turn into a 6 speed one day.
What kind of sound deadening?? I highly doubt this is true because, maybe it's just my car, but I have already ripped most of my interior out and I can tell you it is no different in my 91 Z than it was in my 89 RS. Everything from the rear hatch forward seems to be the same. Maybe I missed something?
Old Oct 12, 2004 | 01:09 AM
Morley's Avatar
One thing was the adhesive used in the body panels and there was supposed to be a spray on material inside the doors, fender wells etc...I don't know that you'd be able to tell it was even on there, being a spray on it was probably pretty thin and they wouldn't want it to increase the weight of the car.
Old Oct 12, 2004 | 08:56 AM
305RSlc's Avatar
Honestly, it all looks the same to me as far as the adhesives for the body panels goes. It's the same kinda pale peach color adhesive on both cars. I have my door panels off right now as well, and I didn't see any kind of spray material anywhere. But like you said, it'd probably be pretty thin. I can tell you for sure that my 91 Z rides a ton smoother than my buddies 85 T/A, which was worlds ahead of my 89 RS in ride quality.
Old Oct 12, 2004 | 11:30 AM
Duck's Avatar
Engine: 5.7
So if someone wants to "tame" the harsh ride of the pre-'91 Z28s, is it simply a matter of changing the springs, shocks and suspension bars to those used in the 91-92 Camaros?
That's pretty easy... Can anyone verify this with parts numbers?
Old Oct 12, 2004 | 06:06 PM
305RSlc's Avatar
I stand corrected. I went outside today, still trying to get my F*CKING Longtubes on, and while under the car, I did notice that there is some sort of sprayed on liner in the wheel wells and sort of near the subframes. It kinda looks like a really thin layer of sprayed on bedliners for trucks. The subframes are, instead of just being stitch welded together, bonded by the same stuff used to bond togethter the body panels insde the car. That would probably lead to the car being a bit "sturdier" or "smoother" than older model years.
Street Lethal
Apr 30, 2019 12:14 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
okfoz
Sep 17, 2015 10:30 AM
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
AkDrifted
Aug 17, 2015 07:45 PM
