which is stronger 9 bolt or 10 bolt??
Old Oct 10, 2004 | 10:25 PM
transam84's Avatar
I have 2 rear ends right now and I am wondering which one to do the 3:73 gear swap with. I have a 3:27 9 bolt and a 3:23 10 bolt, both are posi. would either one have a sig advantage over the other with the same gear ratio???
Old Oct 10, 2004 | 10:52 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
9 bolt is far superior to a 10 bolt in strength.
Old Oct 11, 2004 | 12:00 PM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
The 3:73 swap would be easier in the 10 bolt as parts are easier to come by. But depending on brakes 9 bolt beats 10 bolt in parts you have now.
Old Oct 16, 2004 | 06:55 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
10 bolt with a girdle, good gears, setup right and you should be good. A few of us run 12s/11s on 10 bolts.
-- Joe
Old Oct 16, 2004 | 11:59 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
A 9-bolt is defiantly stronger then a 10-bolt in stock form. But like anesthes said, if you build up a 10-bolt with aftermarket axels, gears, carrier, girdle, solid crush sleeve then it will be the same strength or stronger then a 9-bolt.
Old Oct 17, 2004 | 09:27 AM
88fbird's Avatar
Car: 84 S-10:(
I guess 9 bolts are stronger, but when you do blow them up like I did, it is nearly impossible to get parts. Like it was said before, a 10 bolt can be made to be as strong, with a huge aftermarket selection. Which you don't have with the 9bolt. So, if I had to pick. Stock for stock, drive on the 9 bolt. Then put the gears in the 10 bolt and beef it up. When you are done swap them out and sell the 9 bolt.
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Numbah-1
Sep 12, 2015 08:57 PM
Saxondale
Exterior Parts Wanted
Sep 7, 2015 06:11 PM
Jlanz55
Sep 6, 2015 07:28 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
