98 Spindles on a third gen
Old Oct 14, 2004 | 02:16 PM
cocacolakidd's Avatar
Car: 84Z & Porsche
Engine: 427sbc - 471 - 850 Demon Claw
Transmission: Bowtie stage II TH700R4 - 10" 3000
Axle/Gears: 9 Bolt w/ 3:45's
I have found a braking system for use on my 84Z. It requires me to replace the OEM spindles with 98Z Spindles...well I'm thinking not a big problem yet. Then I'm thinking to go with 2" drop spindles and OEM springs as this would give a better ride than lowering springs (now have 1 1/2" drop springs). Problem now! cannot find any drop spindles for 98Z's...does any one know where to find drop spindles for a 98Z? Or it’s back to the drawing board and use modified 3rd gen. drop spindles for an upgraded front brake system?
Old Oct 14, 2004 | 02:22 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
98 spindles will not work on a 82-92 front end. The 98 spindles use upper & lower ball joints; the 82-92 uses a lower only, and a strut. Completely different. So the 98 Z28 take-out stuff on eBay right now will not work; at least, the spindles won't.
Old Oct 14, 2004 | 04:40 PM
Car: 84Z & Porsche
98 Spindles on a 3rd. Gen
Well that solves that problem. I found a braking system, and was instructed to use 98Z spindles to make it fit my 84Z from the company...They stated that it would fit by using 98Z spindles on my 84Z, but obviously I was misinformed as to the possibility of it working. So it’s back to dropped modified spindles for my 84Z, to up-grade the front brakes system. Thanks for the warning, Ed.
Old Oct 14, 2004 | 04:44 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Just because you can't use the spindles doesn't mean you can't use the brakes. If big brakes are what you want, look into the LS1, C4, or C5 brake upgrades and also the upgrades that vendors like Spohn offer.
I run the 12" 1LEs and 13" C4 HDs on my cars and both are great setups.
Ed
Old Oct 14, 2004 | 05:01 PM
Car: 84Z & Porsche
84Z Brake Up-grades
I have been considering (and saving for) the Spohn System, and modifying the front spindles for it to fit. So far their system fits with all I want to do...By cutting and re-drilling dropped 84Z spindles the Spohn front system will work. Their better, bigger brakes in front, and a decent ride after lowering is what I’m looking for. Thanks for all of the info., Ed.
Hotrodboba400
Dec 10, 2019 07:07 PM
nugentcj
Camaros Wanted
Dec 22, 2015 02:58 PM
my86bird
Oct 23, 2015 12:20 PM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
