do i need to re-align the front end if...
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
i only took the struts out of the tower mount and DIDN'T break them loose from the spindle assy? i took everything out as one piece, including tie rods, but didn't mess with the length on those, either...
KAM
KAM
Car: 86 IROC-Z (daily driver) 87 IROC-Z (under construction)
Engine: 305 H.O.
As long as you only took the strut out of the tower mount and didn't break loose the strut tower mount, you will be fine. And for the tie rods, as long as you did not mess with the tie rod sleeves, you will be fine on that too.
What made you take all that stuff apart?
What made you take all that stuff apart? Thread Starter
Car: '91 Z28
Axle/Gears: 323's
Terrell351
Jun 13, 2021 01:13 PM
