4th gen and 3rd gen interchangability
Old Oct 24, 2004 | 02:12 PM
F-Bobby's Avatar
Car: 1989 Formula 350
Engine: Stealth Rammed 350
Axle/Gears: 3.45 9 bolt
Im wonderin whch suspension componets from a 4th gen will fit on to a third gen with little to no modification. I did a search but all i found were questions about 4th wheels and brakes. i wanna know fi LCAs SFCs Etc will bolt/weld up. Also can i use a 4th gen catback setup on a 3rd gen? Thanx
Old Oct 24, 2004 | 02:20 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
all the suspension in the back is the same. the rear end can be used, but it is 2 in wider on each side. subframes are different, no to sfc. the front suspension is completely different. cat backs can be used but they have different mounting locations
Old Oct 24, 2004 | 04:26 PM
F-Bobby's Avatar
thanx, that helps out a lot. now when i see 4th gen parts for sale ill know what i can buy.
Old Oct 24, 2004 | 06:20 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
i forgot to add, aftermarket torque arms might not work if theyre not tranny mount
Old Oct 26, 2004 | 12:40 AM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
Rear shocks, LCAs, and torque arm (stock mounting as mentioned) will all work as well as entire rear end and springs. I have an LS1 rear with LS1 brakes in my car, and it looks nice with the tires kicked out 1 5/8" on each side (not past the fender flare though)
Warlocksirix
Sep 3, 2015 12:26 PM
cam-mike
Aug 24, 2015 07:23 AM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
jbd1969
Aug 17, 2015 07:06 PM
