Tire Questions
Old Oct 27, 2004 | 09:17 PM
klumb15's Avatar
Tire Questions
i'm looking at tires, and the treadwear number is a bit confusing...is the lower the number the stickier the tire is, and the higher the number the stiffer it is and the more solid it is??? i've been lookign and some are like 280, 420, 360...and also what about the other mumbojumbo, temperature A, traction A...what does that mean???
Old Oct 28, 2004 | 01:03 AM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
not sure on the number for wear but the traction a is best then b then c.
jeff
Old Oct 28, 2004 | 01:45 AM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
Transmission: DYT700R4 custom inerts and conv.
The treadwear rating is how long the tire will basically last. Every 100 increase is twice the wear resistence in rubber compound and is generally but not always a stiffer compound rubber.
ex 250 will last 2.5 times as long as a 100.
AA is the best WET traction rating, then A, B & C. Again, this is WET traction only.
A is the best resistence to temperature- meaning greatest resistence to overheating. C is worst.
Old Oct 28, 2004 | 03:39 PM
klumb15's Avatar
so if i want my tires to last a long time i should get a hi tread wear number...like around 350+ or so???
Old Oct 28, 2004 | 03:42 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
High tread wear numbers in most cases results in poor handling. Depends what you want in tires, handling or tread life???
Old Oct 28, 2004 | 03:46 PM
klumb15's Avatar
well i want tires that won't leave a huge amount of rubber..because my friend has a SRT4 and his tires are pretty sticky, and just from trompin on it and putting a lot of force on the tires they wear down tramendously...so i want a tire that is not gonna slide out on me really easy, but i don't want a really sticky set that only lasts me like 6 months...
Old Oct 28, 2004 | 07:10 PM
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
A few years back, I had a set of Dunlops on my IROC. It was like it was on rails, you could do "Bat-Turns" with it. But, they were quite soft and they wore out very quickly. Too quickly. Yeah, driving it was fun, but at $160 per tire, I want more than 2 years. The original gatorbacks lasted longer, but were noisey as all hell, and terrible on wet roads.
I think I might try the g-force T/As next.
If you *drive* your thirdgen, then you definitely should get only tires with at least a VR, if not a ZR speed rating, and get A ratings on both temperature and wet traction.
Old Oct 28, 2004 | 09:05 PM
klumb15's Avatar
so whats a good treadwear rating?? something that has the best of both worlds..
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
demontransam89
Wheels and Tires
Dec 28, 2015 06:58 AM
69 Six Pack
Oct 5, 2015 07:51 PM
redmaroz
Aug 16, 2015 11:40 PM
