coil spring indexing with tubular a arms??????
Old Nov 2, 2004 | 09:57 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
well, dont wanna do the job unless i do it right. i know the stock springs need to be indexed in the stock a arms.
what about stock springs in a tubular a arm? do i need to use the holes in the stock a arm as a guide, or does it matter?
Old Nov 3, 2004 | 07:58 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
AFAIK, tubular arms have no indentions for the springs. Those I've seen have flat circles for spring perches.
Ed
Old Nov 3, 2004 | 09:04 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
so its ok just to put them in any ole way and let it go? ive got stepped isolators for the springs, so there is a flat surface on each side of the spring now anyway. with the k member and a arms i wanted to make sure.
Old Nov 4, 2004 | 12:07 AM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
Transmission: DYT700R4 custom inerts and conv.
Is there at least some kind of pocket that the spring is retained in on the A-arm? SOme of these aftermarket arms are scary the way they are designed- most of the perches are very cheaply made and can either snap off with suspension travel binding forces or the spring can even walk its way out of there entirely. Just be careful.
Old Nov 4, 2004 | 10:57 AM
theno1prince's Avatar
Car: 1987 Chevy V10
Engine: 5.7L
Axle/Gears: 4.10
If you hold the a-arm level, one side of the perch should be lower than the other. This is where you want to clock your springs, on the low side. Easiest thing to do is to mark the top of the perch while the a-arms are out of the car. This way all you have to do is line up the spring with the mark.
Old Nov 4, 2004 | 06:40 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
they are made kinda cheesy. on the otherhand, i cant see PA making a cheap part that will break. thats just dumb. i wouldnt recomend these for roadracing or autocrossing. i have skinnys up front and no sway bar, drag shocks, etc. i only take corners at the speed limit. strait-a-ways are a different story.
morrow
Jan 13, 2024 12:29 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
New2Chevy
Sep 28, 2015 12:35 AM
SG91camaro
Sep 5, 2015 10:27 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
