Wheel stud size on flang end
Car: Only a daily driver, but comin home
Engine: I have one that runs ;)
Transmission: Caged hamster that runs really fast
Axle/Gears: They are round, I know that much
ok, the wonderful search engine worked, but not for what i was looking for. I have an 88 Iroc with the Borg&Warner rear end and i want to put longer studs all around and try to avoid drilling the holes out. i want to know what is the stock size for the end that catches inside the rotor?
otherwise i will just pull and drill if i have to or it is recomemded for running sticky tires
Car: '88 Formula
Transmission: T-5... in need of slight rebuild
They're the same for the front and rear. I used the motormite/doorman parts. If you search my username and studs you should find the post. I don't have the numbers right now.
Car: '87 Cam RS V6
Engine: Top Secret
Transmission: DYT700R4 custom inerts and conv.
I run ARP studs on mine with IROC rims. They press directly into the front hubs and rear axle flanges wothout any drilling. They are 12mmx1.5 threads (same as stock) and are 2.5" long.
http://www.jegs.com/cgi-bin/ncommerc...32&prmenbr=361
I also run Kyokugen lightweight racing lugnuts.
Car: '88 Formula
The ARP studs can cause cracking when they are pressed into hubs for an upgade package, but from what I hear they are fine for rotors that are not turned into hubs. That is why some use the doorman studs instead.
toronto formula
Nov 10, 2015 06:17 AM
IrocZ'85
Aug 17, 2015 06:24 PM
knight72
Aug 10, 2015 09:32 PM
