Easy way to calculate spacer size...
Car: 94 Camaro
Engine: 383 Stroker
Ive been seeing many people, myself included, ask questions about what adapter size they will need to run 4th gen wheels etc. on their car. Since the backspacing on a wheel is just the distance from the center, you should be able to just go to:
www.convert-me.com
click on distance, type in the backspacing of your wheels in the millimeter section, click convert, then scroll down to the non-metric list accross from the inch.
Remeber that number, and buy the spacer that is larger and the closest to that size.
This is an easy way if you dont like to do conversions and dont know the metric to standard conversion numbers.
Somebody please correct me if any of this is wrong.
www.convert-me.com
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
A less annoying site is http://www.onlineconversion.com
Or you can just go to google and enter something like "24.3785 inches in millimeters"
http://www.google.ca/search?hl=en&c2...in+millimeters
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
Originally posted by askulte
You can just use a calculator too - divide inches by 25.4 for mm, or multiply mm by 25.4 for inches.
multiply inches by 25.4 for mm, and divide mm by 25.4 for inches
Supporter/Moderator
Car: '89 Z28tt
Engine: Dart Little M Twin Turbo
Doh! It's easier doing it than typing how
He he he.
For alternative methods, you can (on your Texas Instruments TI-85 Graphing Calculator) enter the value in inches, hit the CONV key, pick inches>mm and hit enter.
Andris
He he he.For alternative methods, you can (on your Texas Instruments TI-85 Graphing Calculator) enter the value in inches, hit the CONV key, pick inches>mm and hit enter.
Andris
3.8TransAM
Oct 1, 2015 07:47 PM
