275/50 R15's????
Old Nov 12, 2004 | 12:15 PM
ss400hp's Avatar
Car: 2001 NBM Z-28, 1987 Camaro
Engine: LS1, LS1
Axle/Gears: stock and stock
275/50 R15's????
will they fit on the back of a 87 camaro with 15X8 torq-thrust II's??
BF Goodrich G-force drag T/A's 275/50 R15
Old Nov 12, 2004 | 12:34 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
stock ride height?
with the proper backspacing they should fit.
Old Nov 12, 2004 | 12:38 PM
ss400hp's Avatar
Engine: LS1, LS1
It has the Eibach pro-kit springs, and the backspacing is perfect for 245's, can't remember what it was though but there is at least 2-1/2 inches from the 245's to the inner fender. Maybe I'll be lucky
Old Nov 12, 2004 | 04:39 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
i didnt have any problems with 255/50/16 which are the same diameter as 275/50/15s. im running a pro kit
Old Nov 16, 2004 | 09:20 PM
whitez406's Avatar
I ran 275/50-15 drag radials on 15 x 8" draglites with 4.5" backspacing and didnt rub and 5.5" backspacing and didnt rub. I didnt like when they sat even with the wheelwell so i went to 5.5" instead. Even with the 4.5" if its lowered i still would of cleared with no problems.
Old Nov 17, 2004 | 06:08 AM
82TAusmc's Avatar
Car: 1982 Pontiac Trans Am
didnt have any problem with my 295/50/15 on pacer 15x 10
Old Nov 20, 2004 | 05:03 PM
steve87iroc's Avatar
Car: 1987 iroc z
Engine: 355 dart platinum 215cc heads
Transmission: <<BLOWN UP TH400>>
Axle/Gears: 10 bolt 4.11's
I have 295-50-15 and the fit perfect with weld racing pro stars 5.5 inch backspacing.
nicksL98
Dec 16, 2003 08:59 PM
Hg
Nov 29, 2003 04:12 PM
Hg
Jun 16, 2003 02:32 PM
