help my suspension choice
Car: 1999 Firebird Formula
Transmission: Stalled 4l60e
Hi I have searched through this area as well as elsewhere. Question is what are the suspension pieces that I should change for the best handling. I do not care about improved traction as much as firmness and responsiveness. I have the WS6 suspension setup and want to know the best pieces to help my cause. I do not want to replace every last piece. I also know that 1 item will not make things better because it is a system of pieces that work together. Please tell me the main pieces to get the best bang for the buck.
Car: '87 Cam RS V6
Engine: Top Secret
Transmission: DYT700R4 custom inerts and conv.
Great shocks and struts. This is the very first thing needed for any car to really handle well. Get some Koni "yellows" if you want a true handling improvement with only one modification.
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
good shocks, good tires, best bang for the buck.
i don;t know the ws6 susp at all but i though that was one of the better suspension set ups for our cars.
SFC would help you with body roll and flex. That would be a good one too.
gixxer92
May 18, 2017 11:20 AM
LT1Formula
Oct 8, 2015 08:34 PM
