9 bolt drum to disc swap
Old Nov 18, 2004 | 02:16 PM
Eric's85TA's Avatar
Car: 1985 Trans Am
Engine: 400
Axle/Gears: 3.70
My 9 bolt currently has drums, and I found a 9 bolt with discs. If I get the backing plates and everything, will there need to be any modifications made to my axles, or will everything bolt up? Also, exactly what will I all need from the donor car to make this work. I'm sorry if this is all a stupid, redundant question, but I tried a search, and couldn't find anything specifically about a 9 bolt.
Thanks,
Eric
Old Nov 18, 2004 | 02:58 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
9 bolt to 9 bolt should be a direct swap.
Ed
Old Aug 13, 2005 | 06:58 PM
tony1784's Avatar
Car: 85 Trans Am
Engine: SBC
Transmission: TH400
Axle/Gears: Moser/Strange 9"
Sorry to bring back a post from the dead, but I'm interested in the same swap. I have a 9 bolt open drum rear in my 85 right now, and I have an 85 posi disc 9 bolt rear. Would the new rear swap in with no other mods?
Old Aug 14, 2005 | 09:10 AM
ebmiller88's Avatar
Yes, just swap the brakes over...they're the same rear after all.
Ed
Old Aug 15, 2005 | 01:50 AM
tony1784's Avatar
Car: 85 Trans Am
Engine: SBC
Transmission: TH400
Ok, I just wasn't sure about the e-brake lines and prop. valve.
Old Aug 15, 2005 | 09:04 PM
ebmiller88's Avatar
Technically, you should swap the prop valve to the 1LE part but I'd try them out first and see how they work.
Ed
hectre13
Dec 11, 2023 08:14 AM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sailtexas186548
Jan 19, 2016 12:21 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
