Help Im Going To Lower My Z28
Old Nov 24, 2004 | 11:42 PM
Ronbos86Z28's Avatar
Car: 1986 Blue Z28
Engine: 305 H.O
I have a 1986 camaro and I am about to order 1.75 lowering springs in the front and 1.5 in the back is this enough. I am going to get the shocks and struts to is that it?
Also I currently have a strong 305 H.O would it be best to bore and build this moter or go with like a small block 400.
Old Nov 25, 2004 | 02:26 AM
sellmanb's Avatar
Car: '86 Berlinetta
you'll need to add an adjustable panhard bar to your list as well.... can find one off eBay for fairly cheap
Old Nov 25, 2004 | 09:14 AM
Car: 1986 Blue Z28
Engine: 305 H.O
????????HELP
So what does the panhard bar do and according to the research I've done it has to be welded in is this true? Do you have to get the relocation brackets.
Old Nov 25, 2004 | 07:00 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
nope your confused
panhard bar goes across the axle left to right top to bottom. when you lower sometimes the axel will sit off to one side a bit. adjustable panhard will allow you to true the rear end up under the car.
when you do the fronts you will want new ball joints cause your there and posibly new bushings if it needs it.
jeff
morrow
Jan 13, 2024 12:29 PM
greenyone
Sep 2, 2015 03:39 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
