This is going to sound dumb, but..
Old Nov 28, 2004 | 05:56 PM
92RSSlowmaro's Avatar
Where are the bleeder screws on the rear drum brakes?
Old Nov 28, 2004 | 06:30 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
They're hidden! They're right above where the brake line enters the wheel cylinder. Use an 8mm socket. I remember years ago there was a tool; it was a combination socket-on-a-stick with a clear vinyl tube poking out the rear. Allowed the brakes to bleed thru the socket, then you'd just tighten up the socket with the handle.
But I can't find it anywhere; nobody else but me has heard of it - unless I dreamed it up? But here's what I do- First, crack the bleeder free (might need an 8mm socket on a 3/8th ratchet) and just tighten it back down very slightly so fluid barely drips out. Then slide your vinyl tube over the bleeder valve nipple. To open the bleeder, just twist the vinyl tube- it should also open the bleeder just enough. When you're done bleeding, close the bleeder by twisting the vinyl tube again.
Then I tighten the bleeder with an 8mm socket on a 1/4" drive hand-driver, instead of a ratchet.
Old Nov 28, 2004 | 11:25 PM
Ah, you mean behind this rubber boot.
/automotive idiocy moment.
Old Nov 28, 2004 | 11:48 PM
Spdfrk1990's Avatar
No on the other side of the backing plate on the cylinder.
Lbibb
May 5, 2016 12:00 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
wanext
Oct 6, 2015 12:18 AM
Fanatic1074
Oct 2, 2015 03:47 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
