Adjustable Torque arm.
Old Dec 8, 2004 | 12:37 PM
iroc-ice's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
Transmission: 700-R4
Is there any really good reason to have an adjustable torque arm, or will a regular torque arm be just fine. My car is daily driven. Its never seen the track, and it won't see it alot, but occasionally. Thanks.
Ray D.
Old Dec 8, 2004 | 12:50 PM
drop-top IROC's Avatar
Engine: 305 TPI (LB9)
Transmission: WC T-5
An a adjustable torque arm allows you to dial in the pinion angle on the rear end. If yours is just a daily driver and not a hot rod, the fixed torque arm should work fine.
Old Dec 8, 2004 | 05:12 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
for a car making a lot of power with slicks and is for drag racing, having an adjustable pinion angle helps with the tuning of the chassis so you can plant the tires harder. honestly, if you don't ever see any track time and the car isn't going to see track time, i might put a poly torque arm mount on the car and call it a day.
Old Dec 8, 2004 | 09:13 PM
iroc-ice's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
It'll see some track time occasionally, but not now. I don't plan on beating on it all the time so I guess I'll go with a fixed one.
84LsxZ28
May 17, 2020 02:21 PM
J-money
Jan 4, 2019 09:45 AM
Nervous2
Oct 8, 2015 10:53 PM
luvofjah
Sep 26, 2015 08:28 PM
Ragtop Man
Sep 12, 2015 12:23 AM
