Need rear suspension advise
Car: Red 91 RS Camaro
Engine: LO3 with Comp Cam
Axle/Gears: 4th gen rear
Ok heres the problem. I bought dropzone lowering springs for my camaro and I'm happy with the front but not with the rear. The rear DZ springs were much shorter than the stock springs and made the car lean back. I bought 1.5in osilators for the rear and it leveled everythign out. I've had it like this for about a year now and lately I've noticed that the right rear has been hitting the bump stops going over moderate sized bumps. Naturally I asummed it was the 1 year old KYBs going out cause they don't last long so I replaced it with a monroe sensatract just to see. The problem didn't get any better. Rest of mods are in the sig.
Does anyone sell just the rear springs for these cars?
What about the helper airbags that go inside the spring?
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
I believe Moog sells springs individually. But they will be the stock height spring and may be too tall.
Car: 83 Z28
Engine: vortec 305 for now
Transmission: 5 speed
The springs are used to hold the car up, the shocks dampen those springs. I used Koni springs and noticed the same thing. I ended up using Z28 springs and cut them 1 full coil. For some reason the aftermarket springs seem to let the rear of the car down. This might be in order to get a 50/50 weight bias.
Its just really annoying cause even going over speed bumps it doesn it. I'm thinkin some better springs from Eibach and some koni yellows or some tokico illuminas
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
Re: Need rear suspension advise
Originally posted by iggy1991
...I've had it like this for about a year now and lately I've noticed that the right rear has been hitting the bump stops going over moderate sized bumps. ...
https://www.thirdgen.org/techbb2/sho...hreadid=267885
http://www.f-body.com/forum/showthread.php?t=8613
All 4 hieghts are pretty much around 26 inches. I'm wondering what the spring rate is for the Dropzones compared to the Eibachs or others.
bjpotter
Jan 22, 2019 12:27 PM
